4l80e lockup problem
Old 07-02-2011 | 10:35 AM
  #41
Boosted_Silverado's Avatar
Originally Posted by Circle-D
Very good to hear. Did you end up doing the Sonnax valve?
Chris
no i never did the sonnax valve, if i ever need to pull the trans open again i will do it next time.
Old 07-02-2011 | 12:18 PM
  #42
Circle-D's Avatar
Former Vendor
I was just curious as to what fixed the converter issue. Maybe the old pump volume was to low at idle???
Chris
Old 07-03-2011 | 04:32 PM
  #43
Chris
i had the truck out last night and it seems when the trans temp get to 150+ the lock up problem acts up a abit in reverse only.
not so much that it bogs the truck down to stall out but it is noticeable abit
did someone mention their was a spring i can replace in the pump to make more pressure at idle? or how does that work?
Thanks guys.
Old 07-05-2011 | 12:13 AM
  #44
anyone? i bumped the idle up in my truck 100rpm and it helped abit but its still just happening in reverse only.
Old 07-05-2011 | 08:15 PM
  #45
Circle-D's Avatar
Former Vendor
I will try and get some pics for you tomorrow...
Chris
Old 07-06-2011 | 04:03 PM
  #46
Circle-D's Avatar
Former Vendor
You need to add an inner spring to the "Converter Limit Valve" Factory limits it to ~100 PSI. Adding an inner spring will bring it up to ~150. This will increase the pressure and volume to the converter. Let me know if you need anything...
Chris
Old 07-06-2011 | 05:55 PM
  #47
ok where can i get one of these springs? it looks like i will need to pull the pump out to get to this right?
Thanks!
Old 07-06-2011 | 06:05 PM
  #48
Circle-D's Avatar
Former Vendor
Thanks!
Correct, out and apart. I can send you one, just take a while...
I would also put the Sonnax valve in, could be VB wear as well...
Chris
Old 07-06-2011 | 08:10 PM
  #49
ok sounds good, i would like to get one asap.
also where can i get the sonnax valve from?
thanks.
Old 07-06-2011 | 09:10 PM
  #50
Circle-D's Avatar
Former Vendor
thanks.
I sent you an email........
Chris
Quick Reply: 4l80e lockup problem
