4L80e pan wont fit. help!
Old 03-16-2013 | 05:05 AM
Ron_Stoppable's Avatar
Default 4L80e pan wont fit. help!
I have a 95 4l80e out of a van. i decided to swap to a new pan that has the drain plug. its AC delco part #24204278. i went to install it and it wont even lay flat on the rear of the pan because that rear bushing lube tube sits up too high. the pan has more shallower angles than the stock pan that was on it. fml. someone help me out. what exactly do i need? all i want is a stock pan with the drain plug. is the one i have for newer 80es or something?
Old 03-16-2013 | 08:59 AM
03sierraslt's Avatar
The older pans had the drain on the side of the pan. They are different then the newer pan.
Old 03-18-2013 | 02:36 AM
im returning it to amazon tomorrow. would you happen to know the part # for the correct pan i need?
SloSVO
11-22-2020 08:34 PM
jscherbs
09-30-2015 08:54 AM
lxcoupe
09-25-2015 01:36 PM
69z-28
09-21-2015 08:31 AM
