4L80E Problem
4L80E Problem
Ok, finally got the 4L80 swapped in and only the 3rd day out broke it.
What could this be?
I came off the highway and launched it hard of the next intersection and when the next time I stopped, the trans starts off in second and when the shifter is put into first, the truck does not move at all. It feels like a trans brake and the engine stalls at times.
What could this be?
Just had a chance to drive it again, its starts off in 3rd and does shift to 4th. When the torque engages, the trans will sometimes rattle and stalls at times but then the converter would loosen up again. The fluid is smoked bad!!
What do you guys think happened?
the trans was built, it was a gamble, the trans came out of a 08 tahoe that someone swapped a 427 Z06 motor into, the trans does have really good parts in it and was advertised to only have 1500 miles on it. the trans bad bad out of the box or it was just my luck.
the good thing now is all of the little stuff is done to get the 4L80 in the truck, now its 45 min out and 45 min in.
