4L80E Question...
How do I change this text
Definately avoid 91-93 models entirely - they have a 292.5Hz. Pressure Control Solenoid and 91-92 units have the wrong connector. (1994 and up models have a 614Hz. Solenoid compatible with the PCM.)
1994-1996 cases have the old style linkage, adapting the newer neutral safety switch and linkage will require improvisation. These cases also have the cooler lines in the front, 1997 and up have the return line in the back.
1997-1999 cases do not have the top bolt hole.
1999 and up have 10% larger sun gears and wider manual second band.
2001 and up have a better overrun roller clutch in the overdrive, rollers won't skew.
The larger gears in the reaction carrier of the 99 and up can be retrofitted to the earlier cases, as well as the overrun sprag in the 01 and up transsmissions and the second band.
BROKE-aSS-BLAZER
10-13-2017 03:50 PM
jscherbs
09-30-2015 07:54 AM
