4l80E Rebuild Thread
#41
Cool. I need to pick up a tranny holder and mount and get started. I need to also pick up the 4th lip seal installer. I drained the fluid out of mine yesterday. It was actually in pretty good condition... no burnt smell. I'm hoping I have the updated roller clutch / turbine shaft. My tranny is a 2001... we'll see. I wish Autometer made a Cobalt tranny pressure gauge.... hehehehe
Thanks for the update.
Bill
Bill
#42
The pin fixed it! I ground the pin down to 1.310", I was going for 1.315" but it ended up a little shorter once I finished. Shifts are 10 times better now. I still want to check the pressures just to know what they are running. I'll have to drive it awhile before I decide to keep it like this or shorten the pin some more. At least it doesn't feel like I'm being rearended during my 1-2 shift anymore.
You know, you could probably do the rebuild without the holding fixture, if you have plenty of workbench space. The 4l80E is one heavy MF though, so I'm glad I bought the holding fixture.
#43
[IMG][/IMG]
I'm not sure if your book tells the proper location of this snap ring. Take it and put it at the 3 o'clock position. Basically a 180* from where you have it. The reason for this is with a wider snap ring it will rub the direct drum(high reverse drum). When the intermediate clutch is applied the pressure plate will flex that snap ring and it will rub with it in the position that you have it. Looks like you are having a lot fun. Enjoy!!! Vince
Hi guys,
Excellent read !
Can someone please explain to me how the snap ring would work better spun 180*
If it's a round ring how can it make a difference .
Wouldn't it sit exactly the same , no matter what clock position the split was at?
Sorry if it's a dumb question, I'm new to this sort of thing.
cheers
#44
FormerVendor
The snap ring will rub on the direct drum! That is why I pointed it out. When I see this it is usually done because the guy building the trans did not have a lot of experience building. With the factory snap ring being narrow compared to the wide ring that most of us get in the transgo kit, it may or may not propose a problem.
#47
if the ring is the same width all round , how would rotating it give more clearance?
Apologies once again,
cheers
#49
Thank you very much Vince for sharing that information.
You are a highly regarded member on these forums and was never questioning what you where saying.
I was just trying to work out how.
Keep up the good work ,
This is an awesome site with many helpful hands.
cheers
