4l80e shifts to 2nd when in first... need help!
Jamie, do you have the capability to datalog the issue?
Sounds like you have it narrowed down, as you know the issue is not a mechanical problem now. Some things I would check would be the tune as you stated, the TPS, and especially the pinouts of the harness/PCM.
Also, what year truck is the trans out of? IIRC, there was a change in the 4L80E around 94-95. You may want to double check, or maybe someone else here knows -- but can the LS PCM control both a post & pre 94/95 4L80E..?
jtphelps289
09-29-2015 12:00 PM
jtphelps289
09-01-2015 08:58 PM
