4l80e for sled pulling truck
Wow what a pile of useless info. I'm sure if he was into race trucks he wouldn't be pulling a sled. I'm also confident that he is pulling in the stock GAS class so a d-max wouldn't be allowed.
Anyway OP, a healthy 80e bone stock will be fine for what your doing. I see a lot of guys manually locking the converter once they get the sled moving and swear it helps.
Sled pulling is overrated.... Especially in NW Ohio everybody and there brother does it.. u should build a racetruck with what you have not a pulling truck. If you want a pulling truck buy a duramax like everybody else imo. A stock 80e should be suffice, but i would run the 60e till she blows you will break other parts before the trans though. worry about other modifications first before a transmission.
Not really sure it was all useless? Obviously a duramax wouldn't be allowed in a gas class not real sure where that one came from. If he wants a pulling truck buy a duramax and pull work stock or 2.5. I was just putting in my 2 cents pretty much saying he is wasting money trying to make a half ton gas truck into a pulling truck, just beating a dead horse doing that. But to each there own.
So far I have smoked a stock 60e at 70k mi. Next rebuilt it and proceeded to kill a converter. And finally on fresh rebuild with billet converter poped a output shaft. So at this point I'm done trying to run a 60e in a 6500lb truck.
Also for the rest of the drive line its on par with a top tier 2.6 truck as far as axles and drive lines go. So its not really a half ton anymore.
As for build a race truck why would I do that when about every track is two hours away and I can be at multiple different sled pulls with in a hour of me. And if I want to go race I'll hop in my cummins tow rig and race that. Or once I get my ultra 4 car finished I'll go race that and get a real adrenalin rush.
Finally you basically tell me I'm pissing up a rope trying to pull street stock with a half ton truck, witch in theory I could pull that off for 10k or less. So instead you tell me to get a d-max and pull ws or 2.5 witch I'd say ws would be around 30-40k by the time I buy a truck and 2.5 would be 50k+. Seeing as nw Ohio is a hot bed for 2.5 class and you need 8-900 rwhp to run at the front of the pack. So as I said from the start you don't have a ******* clue.
zaathur151
07-06-2015 11:57 PM
