4L80E Swap!!!! I Need Help Por Favor!!!
Nice!!! you guys freakin rock!!! Alright, so far front ds, rear ds, crossmember, ypipe, are all out the way. Jack and stand are holding the tranny up!!! I'm about to remove the front dust cover from the tranny and start working the TC bolts now. I'll keep ya posted
Thanks fellas!!
Thanks fellas!!
Man I'm still out here tryin to get this damn thing down!!! What the hell are you guys doing to keep the god !@#$ flex plate still??? Everytime I try to losen a TC bolt it turns the plate too!!!
Thanks that worked perfectly!!! Is there any suggestions for getting the cooling lines on the passenger side out!??? Everything is pretty much done except...
Two tranny bolts
A couple electric connections
and the trans case is still on!! I cant reach the top bolts so I was going to try to egt the tranny down first, then I should be able to reach the top bolts, put the tranny back up, slide off the T case, then drop the trans down again!!
Two tranny bolts
High on diesel fumes
Each line is held in with a c-clip. You can take a small flathead screwdriver and pop the c-clips off, then the lines just pull straight out. It's tough to see up there, but that's all that is holding them in. Look at the tranny lines that go into the radiator for reference - same exact type of fitting on the transmission itself.
Glad the rest is working well!
Ok, I'm now to the part that seems like it's going to be the hardest to accomplish!! Top of the tranny last freakin bolt!!! Tell me there's not a special tool I need to get in there????
