4l80e swap shift solenoid issue
The relay method works fine when it is needed and properly done.
The 4L80E has very simple electronic controls, especially for shift strategy. On/off. It just does what it's commanded.
I can't even begin to convey how often we have helped customers and other people diagnose their wiring/tuning issues.
It takes the proper tools and some time.
Understanding WHAT you are trying to accomplish and how it works helps.
I'm pretty sure we offered more tech than to just send you to another vendor for a harness.
Diagnosing this type of issue will require the proper tools.
That being a scanner capable of commanding the shift solenoids. Snap on Modus or Solus, HPTuners, EFILive, etc.
A multimeter.
A wiring diagram.
Key on, you MUST have 12V to the E pin AT THE TRANSMISSION.
You must also have power supplied to the relay if you are using that method.
If you command 1st gear, or the A solenoid, you should have continuity to ground from the A wire on the transmission main connector. That means put the multimeter between the A wire and the transmission case or frame and it should show a fairly low ohm reading. 2-3 ohms max. When you turn the solenoid off the ohms should go infinite, NO continuity.
So in 1st and 4th, the A solenoid will he grounded, but not in 2nd or 3rd.
The test is the same for the B wire and solenoid, except it should be on in 3rd and 4th, and off in 1st and 2nd.
If you are using a relay, you will be commanding this "off" to turn it on.
Be sure your relay is a NO/NC relay with a pin 87 and pin 87a. If it's a NC/NC relay it won't work.
A multimeter.
A wiring diagram.
Sorry if it came off rude, I definitely didn't mean it that way. I'm not sure if you are the person who I spoke with on the phone yesterday, but the answer you just typed up was what I was hoping for yesterday. I didn't really want to buy a harness and just have this exact same issue in the end. I want to know what is going wrong. I also sorta figured it was possibly bc I didn't buy a trans from you guys, which is understandable that you didn't wanna spend time to diagnose my issue. Thank you for the reply and I will try this all tomorrow.
I do have to limit my resources and try to concentrate on our paying customers however we try to help anybody we can.
Oftentimes I can give this same explanation and end up trying to teach guys how to use a multimeter over the phone.
Diagnosing these issues requires the proper tools AND some mechanical know how. I can't teach everybody how to use a multimeter over the phone, so when it gets to that point I suggest that someone seek professional help from an experienced technician.
LCHEE
10-24-2020 04:10 PM
lxcoupe
07-14-2015 10:14 PM
