4l80e users - how do you like your 1st gear?
The 4L80E gets a bad rap because of its gear ratios. My engine makes around 330 hp and 400 ft lbs which according to desktop dyno the torque is peaked at 2000 rpms and stays table top flat past 4000. That being said my engine has zero issues with the slightly higher 1st gear of the 4L80E and I even have the stock diesel torque converter that only stalls at 1500 or so. It just rips through 1st and into 2nd like its nothing and I love being able to take it up to 85 or so WOT in 2nd before shifting. Its great to smack the pedal on the floor at 65 and hit 2nd and pass almost instantly. Everyone says it takes more power to run a 4L80E but I never felt the difference. I have 3.73s and 32 inch tires and it turns a reasonable 2100 at 65 but I would like for it to be lower. I'm actually planning on 4 inch spindles and 35's and staying with the 3.73s. Should work really well IMO.
As it is now I turn 1800 rpm @ 60mph and 2100 @ 70. Not bad at all I suppose.
I'm the type of driver that doesn't like to mash it to accelerate. I like instantaneous throttle response. Even with the 6.0 and 4.10s I feel like the low end is weak. That's why the 2.48 first gear of the 80e worries me. I'm strongly considering a Radix because I think it will suit my driving style.
"We have almost the exact same set up, except I have an lq4. The 80e absolutely sucks out of the hole. A converter is just going to create wheelspin unless you have traction bars and run some type of drag radials on the street. I have a 2800 stall.
I can almost guarentee you that your mph in the 1/4 will go up and ET down with everything else held constant. My 1/8 mile times suck, but the truck runs really well up top. With only 448rwhp I was trapping 108+ in the 1/4.
The 80e is a blast to drive on the freeway and has much better trnasition into gears. The 65e absolutely sucks between gear shifts. The 80e "supposedly" takes an additional 20-25hp to turn as well.
For a piece of mind, do an 80e. For the best performance, go 65e. I honestly dont think a 4l65 will live for an extented period of time in a heavy 6L truck. I should know, I went through 5 of them.
Think long and hard bro. The determing factor for me would be your driving habits. If you drive hard, get an 80e. Just be prepared to be sluggish out of the hole."
Put a Gear Vendors Overdrive behind it to use on the freeway as fifth gear. With that and 4.56:1 gears out back it the truck will launch the same as with a 4L60-E with 3.73:1 gearing, but shifts won't suck.
I don't want an anemic first gear. I had 3.42s with 31.5" tires and the first gear sucked, even with the 3.06 first of the 60e. The 80e's 2.48 combined with the 4.10s I just installed (that means 4.56s are out of the question) will be WORSE than the 3.42s and 60e. I just cannot have that. As far as making more power, I really don't see any other way I can make more low end torque other than a radix.
As of now I'm leaning back towards a built 60e, but we will see.
I have read that GM makes a 2.75/1.75 1st/2nd gearset for the 80e that goes in the RV's. I also heard of aftermarket gear sets similar to the ratios of the 60e. I wonder how much that would cost me.
While that is an option just from a cost stand point its not really worth while IMO. The OD ratio really is not that big of a deal. Yes it will turn a few more rpms on the highway but depending on where you live and your driving style that may not be such a bad thing. It actually works very well around town. I can hit 4th and lock the converter by 32 mph around 1100 rpms and just ease around town all day long and not use much fuel at all. I can also turn 21-2200 at 65 and pull hills almost effortlessly. Honestly I think once you bite the bullet and just do it you will fall in love with the 4L80E and there will be no turning back. I know I wouldn't have my truck any other way.
