4spd Muncie behind an LSx - in my 71' C10
Old 11-29-2012 | 07:34 PM
Benlugchev's Avatar
11 Second Club
Default 4spd Muncie behind an LSx - in my 71' C10
Is anyone got experience running a 4spd NP-440 (A833) behind an LSx. Im doing an LQ4 swap in my 71 C10 and want to keep the 4spd manual tranny. This is not my area of expertise so any help will be appreciated. Which flywheel clutch setup will work the best. Looking to do a LQ4/L92 head with bigger cam in this setup
Old 11-30-2012 | 09:26 AM
Fastcount03's Avatar
I can't remember for sure, but I know I had to get a special bell housing to get it the right length. I used the flywheel and pressure plate from the previous setup, it was behind a 350, and I had to search different year vehicles at autozone for the correct size and spline count clutch disc. As far as what brands, I don't know because I don't have my setup running yet.
Old 11-30-2012 | 10:50 AM
PRO TOUR HOE's Avatar
I am interested in finding out also I am building a 70 2wd blazer roadster and am wanting to run the same set up
Old 11-30-2012 | 06:09 PM
Benlugchev's Avatar
11 Second Club
Looks like I found my answer...
PACE Performance - OMW621LS - GM LS Gen III 11"/12" Clutch Manual Transmission Bellhousing - For Use With Car 3 & 4 Speeds - Muncie, Saginaw, Borg Warner, Richmond Transmissions
GM Flywheel PN# 12561680 & 12" clutch and pressure plate
Also came across this in my research
https://ls1tech.com/forums/conversio...s-motor-2.html
Old 11-30-2012 | 07:49 PM
2doorfury's Avatar
In for answers also..got a buddy putting a 4.8 in a 68 c10 and wanting to run then saginaw
Old 11-30-2012 | 08:38 PM
phasemaster1's Avatar
I used a stock flywheel from a 4.8. A spec ls pressure plate used I bought and got a clutch to match my muncie spline count. Keisler has the bellhousing you need it has an extra hole the ls block has the bell is same as the original 621. I keeped the fork setup works fine. If you have the extra cash I would get the steel bell from quicktime bellhousing. Dont forget the pilot bearing I think it was a ls7 one p/n: 12557583.
Old 11-30-2012 | 09:39 PM
KozzyJr's Avatar
is the Muncie a m20 or m21 ?
Old 12-02-2012 | 09:52 AM
Benlugchev's Avatar
11 Second Club
I got the truck with a GM NP440 4spd manual. or it is close to Chrysler A833.
At this point im going to rebuild the NP440 and switch to a muncie later on when I find one.
Old 12-02-2012 | 03:30 PM
02_Orange_D1SC's Avatar
Fastest D1 Procharged Truck
theres also the M22 AKA the stonecrusher
Old 12-02-2012 | 04:25 PM
KozzyJr's Avatar
yup yup but iirc its called the rock crusher.
kainzien
11-10-2023 12:37 PM
TrendSetter
11-26-2018 08:18 AM
Big_pimie
09-22-2015 10:07 PM
racedad70
09-16-2015 02:51 PM
cousblake11
09-09-2015 07:52 PM
