4wd lanch... what ya think
Old 10-30-2012, 11:23 AM
grm1738's Avatar
Default 4wd lanch... what ya think
guys.. i have a z71 bing built with 500+ hp motor... i would like to race it in 4 high to stop from spinning tires. i am sure some drive trian upgrades are a must.. what has worked for others. ( may end up a round 800 rwhp). what are some good products that work for others.. thanks
Old 10-30-2012, 11:34 AM
I have a gauge for that
Atomic's Avatar
Strap the front end down and get some traction bars.
Old 10-30-2012, 11:47 AM
grm1738's Avatar
do you have any transfer case issues....or issues at all
Old 10-30-2012, 11:50 AM
Atomic's Avatar
Nope, its been rock solid, and my tcase has close to 250k miles on it. The most important thing is strapping the front end down....when it lifts, you will have terrible front end geometry and can easily break cv shafts and have bad torque steer problems.
Old 10-30-2012, 12:10 PM
grm1738's Avatar
what are you using to strap the front end down.. is your transfer case a 1/2 ton or 3/4 ton. also whats your hp
Old 10-30-2012, 01:31 PM
Atomic's Avatar
Nylon limiting straps. 1/2 ton. Around 1000rwhp
Old 10-30-2012, 01:39 PM
nonnieselman's Avatar
Keeping your CV axles straight (parallel to the ground) is the best way to run them.. so if you can strap it down to do that, and your pretty much set.
only other things is a good transmission and a good posi traction in the rear.
Old 10-30-2012, 04:16 PM
Slowest turbo build ever!
black00chev's Avatar
STRESS the trans and rear-end part of that.
Would be wise to rebuild the front diff with factory bearings and seals just to make sure they are in good shape. For the rear, most people on here go with (pick your fav. brand) girdle cover, diff cap studs, and a truetrac.
Old 10-30-2012, 04:28 PM
grm1738's Avatar
thanks guys for the good info.. if a 1000rwhp truck can handel the stock transfer case than i will be well in the clear... i currently have the stock 4l60 e in the truck.. what is the advantage to the 80e if they are both rebuilt for 1000 hp.. what are your thoughts.
Old 10-30-2012, 04:42 PM
03sierraslt's Avatar
You are not going to build a 60e for a 1000hp in a truck. What is your setup? A 80E is a overall bigger and heavier trans, they are a common upgrade due to their strength however they are not a direct bolt in as they are slightly longer (about 2") Weight and power kill transmissions, 60's do not like either.
Quick Reply: 4wd lanch... what ya think
