4wd service light
It will turn out to be the Sensor in the encoder motor. You can change the switch a hundred times and it'll work for a while but it will always go back to fail unless you change the sensor in the Transfer Case shift motor....dealers call it the Transfer Case Actuator.
The sensor part# you need is 88962315 and you'll also need the Actuator seal pant # 12384990.
Around $96.00 for the sensor. Most dealers stock it. I've done plenty of these operations. Trust me.
No problem bro,....just keep in mind that 4 years ago, the quick fix at all dealerships and garages was to replace the difital/analog switch which worked fine....for awhile. Now after a few years of research, GM has decided to produce a tech bulletin advising us that the position sensor i the actuator was the culprit. Some switches were bad...but keep in mind that if yours ever **** out again....replace the sensor and you'll be golden.
carid
10-28-2015 08:24 AM
Tydriver
45
10-23-2015 09:19 PM
bluestang50
09-21-2015 08:36 AM
