4x4 transfer case in awd Escalade
Old 01-09-2022, 08:55 PM
I have a gauge for that
Atomic's Avatar
Originally Posted by Sharty_McQueef
So how can a guy like me (caveman level electronics skills) get that working?
Well sunshine up there is supposed to be making it into a neat little box with a couple wires and a **** so should be pretty easy. Youre welcome
Sharty_McQueef (01-10-2022)
Old 01-09-2022, 10:25 PM
arthursc2's Avatar
Received 1,492 Likes on 1,096 Posts
Getting a little teste in this joint
Old 01-10-2022, 08:02 AM
shakenfake's Avatar
Received 1,271 Likes on 970 Posts
You love testes don't you?
arthursc2 (01-10-2022)
Old 01-10-2022, 08:54 AM
Mod with training wheels
smokeshow's Avatar
Testes is what I live for.
Let me know what other features this thing needs so I can get them tested before making a PCB for it. I figured a front axle disconnect was a no brainer. Three6gmc aka #nobudgetpena also mentioned a speed lockout for N and 4 low.
While I can make the transfer case work easily enough, getting the Escalade to not complain about it will still be on you.
Old 01-10-2022, 07:04 PM
Sharty_McQueef's Avatar
10-4. Just need HPTuners to come out with a BCM beta and good to go lol
But either way lmk when these are available
In regards to the CAD, would I be correct in thinking not applicable to Escalade as the front diff is open?
Old 01-10-2022, 07:18 PM
arthursc2's Avatar
Every 4x4 GM half-ton in the history of ever has an open front diff
While it is a free country and you are free to spend your money how you'd like, CAD does prevent wear on the diff/spiders. Allegedly helps MPG too, and that's why we are here, right?
That said, Dodge and Jeep had about a 15yr period there where all the 4x4s they built didn't have CAD and no one seemed to complain that I remember
If you can find a CAD housing with the proper ratio and similar miles and condition I'd consider swapping. If you can't, and therefore don't swap: I don't think anything atrocious will befall you and your truck
Old 01-11-2022, 07:18 AM
makes children cry
_zebra's Avatar
dang... you got me with 1/2 ton.
i was just about to highlight that the H3 Hummers had an available electronic locking front diff for 2009-2010. it's a weird size, though, and i doubt it'd swap over to a full-size truck.
Old 01-11-2022, 08:09 AM
arthursc2's Avatar
It doesn't swap over directly, regardless of the fact GM made the lug pattern between the trucks the same
Also, the e locker is technically still open, unless locked. Its not an LSD
Old 01-24-2022, 09:06 AM
Let me know what other features this thing needs so I can get them tested before making a PCB for it..
Leaning towards the NP263hd or maybe it’s the 261, whichever one is electronic.
will your system work on these too?
Old 01-24-2022, 10:21 AM
smokeshow's Avatar
The "3" at the end of the transfer case identifier signifies electronic actuation. And yes I believe they are the same (the encoder I have available to test with is from a 243) - if not, the encoding is simple enough to adjust for. However I do not have a transfer case to test the actuation on, so we'd have to figure out how to get it properly tested. Usually I bother my sugar daddy Atomic for that stuff.
Quick Reply: 4x4 transfer case in awd Escalade
