5-7 drop NBS camber
5-7 drop NBS camber
5-7 drop NBS guys what components are you using for camber??? I have used moog offset uppers, DJM uppers w/ offset bushings, belltech cam plates and nothing seems to work
Damn bro the moog offset uppers definitely solved all my camber issues. My setup was 2 inch mcg spindle and atomic fabrication coilover brackets, was at 6 inches in the front and the arms fixed it for me.
I used those when I installed my 4-6 but it didn’t fully aligned... so I took them off since I had some djm uppers laying around then added the offset bushings and it helped better than the moogs but I still have some camber... took it to get it aligned and they told me it’s maxed out
I’ve been reading a lot and came across the instructions for the cam plates... when I installed them years ago I don’t remember having to trim the bolt slots a bit... things didn’t even come with instructions... I’m going to give that a try and see if it makes the trick.. about how much more adjustment should that give me????
Wondering if this has anything to do with you being torsion 2wd, the control arms are the same but frame profiles are different.. Not sure how much more adjustment it would give but definitely try trimming and see if it gets you closer
