5 lug adapters??
As for their strength, I'd only recommend billet aluminum.
i forget his name. i saw pictures of his truck with 5lug drag wheels and 6lug street wheels in the "show off your truck" sticky
There is no answer to how strong are they. I drive my truck everyday on the street and race it on the weekends. I have done 7.8s at the 1/8th and up to 120 mph with no problems. I cant tell you that I recomend them, this is just what I do in my truck.
https://www.performancetrucks.net/fo...d.php?t=422202
https://www.performancetrucks.net/fo...d.php?t=422069
https://www.performancetrucks.net/fo...d.php?t=398045
I wouldn't run adapters on anything, but if you want 5 lugs here you go.
You can just order new rear axles to correct the 6 lug problem, and many places can re-drill your drums to match.
As far as the front disk I never had mine apart so I am guessing a bit here here.
The front hubs may be a bit thick to get a 5 on 4.75 bolt circle drilled in to them, but a 5 on 5 maybe a bit easier. Either way you'll need to fill in the 6 holes and any stress risers so you 5 lugs will seat correctly.
lxcoupe
09-25-2015 12:36 PM
ice17
09-22-2015 05:18 PM
