6.0 to 4l60e B^%ch
6.0 to 4l60e B^%ch
are the 5.3 and 6.0 flexplates the same?? i still lack the length of the dowl pins of gettin everything bolted up..could my tc not be on all way??
FormerVendor
If the 6.0 came out of a 2500hd truck or a van then the flexplates are indeed different, Those flexplates are for 4l80e trannys. In order to bolt up your 60e to that engine you will need a 60e flexplate, You can use the one that came on your old engine if it was a 4.8, 5.3.
FormerVendor
Use your old 5.3 flexplate on the 6L and also you may have a problem bolting up the TC to flexplate one bolt may not fit well into the flexplate just use a drill bit to round it out a bit.
I didn't have to drill on my flexplate to get the bolts in?
Make sure your TC is seated all the way, you may not have it all the way on.
http://www.converter.cc/installguide/guide.pdf
That's Yank's install guide, very helpful
GMCtrk
18
10-06-2015 03:48 PM
Cammed4ever
09-30-2015 03:38 PM
