6.0 LQ4 Borg Warner 4 speed
I recently aquired a 2003 6.0LQ4 engine. I have a 1948 Chevy truck street rod, which currently has a 350. I would like to put the 6.0 in it. I know the motor mounts will have to be moved on the frame, but can someone tell me if the Borg Warner will bolt up to it. I currently us manual linkage and a diagrham clutch, which I want to keep. Trying to to this on a budget, this is a resto rod in looks but under the hood I want real power. The tranny is a 26 spline. Any help would be great
Resto
Resto
An LS1 T56 6speed pilot bushing is the same. I am not sure on distance of block to tranny though. If it is different then Lakewood or Mcleod should make a belhousing for the swap. The belhousing to block bolt pattern is the same as early model. The clutch may be the biggest hurdle as far as flywheel is concerned. Someone has done it before surely.
