60 to 80 swap
60 to 80 swap
First off I'm new to the site, my compliments from what i have read so far wow lots of info.
On to business i have a 05 Silverado 2wd std cab short wide bed 5.3, 4l60e trans w/transgo shift kit 3:73 rear end w/true trac, long tube headers, larger injectors, and a custom tune.
6 mths ago the out put shaft on the 60e broke, i replaced it with a built 65e now it broke. I dont want to waste more money on this trans, is the swap to a 4l80e the answer?
Your input is welcome. Thanks Jeff
Done with the 4L65E
I'm on my third 65e, out put shaft breaks both times and i don't want to do this again. Unless i learn of something else its going to be the 80E swap. I have been reading on hear for hours still have not found the swap info I'm looking for. I'll keep reading.
Thanks for the input Guys
Jeff
Jeff
Jeff
Jeff
I went thru about 15 4L60Es before i went with an 80E..
No problems since.. also a very hard shifting 60E will kill the output shaft very quick. that was one of my problems, i learned later on anyway.
The swap is very very simple..
All you need is a complete trans, TC, dipstick, shifter bracket and Flexplate for 80E.
Mod your Crossmember and bolt everything in,, get a TH400 Yoke and i think you have to get your DS shortened.
Wiring is easy..
https://www.performancetrucks.net/fo...d.php?t=413157
Wiring is easy..
