60e type fluid?
Old 03-28-2010, 10:45 PM
006rcsb's Avatar
whats the difference between the different atf's like dex3 and dex6, and arent the 4l60's between the years the same? so why would they need different atf's?
Old 03-29-2010, 09:48 AM
Where's the Beef?
viciousknid's Avatar
Dexron 6 is a million times more efficient than dexron 3 first of all. They apparently started using newer technology starting in 06 and it requires a better fluid to help stay lubricated. Wish I knew exactly whats different. Majority of the change had to do with the introduction of the 6 speed. It wouldn't last worth a damn using dexron 3 in tests.
Old 03-29-2010, 11:51 AM
PT's Slowest Truck
budhayes3's Avatar
Isn't DexronVI semi-synthetic or something like that? It should be noted that you can always go backwards on GM's with Dex, meaning that you can use DexVI in a trans that originally came with DexIII, but not the other way around. Now for "built" transmissions, I'd go by what the builder recommends...
Old 03-29-2010, 12:34 PM
Where's the Beef?
I put 6 in mine this last time. After reading the test results on it compared to 3 I decided I'm going to just use 6.
it's a huge improvement.
Old 03-29-2010, 12:35 PM
Wearin' da big hat
00ChevyScott's Avatar
I have Mobil Dex VI in mine
Old 03-29-2010, 03:55 PM
SILVERADO11's Avatar
why does FLT recommend Dex III in there performance transmissions ?
Old 03-29-2010, 08:25 PM
Where's the Beef?
Probably cuz you use Dexron 3 in automatic transmissions?
GM started requiring DexVI in 06. I don't build em so I can't say if they started using different parts in 06+ or not or if the specs are tighter. OR if they just want to make more money off the new Dex VI Since they let the DexIII patent expire.
From everything I've read it was designed because the 6 speeds wouldn't stay together and if you use Dex III in an 06+ vehicle GM will void warranty work on your trans.
However after seeing the test results for Dex VI, I don't see why you would want to run III anymore other than to save a few bucks. There is NO comparison between the two, Dex VI is just plain better in every way. That's part of the reason they skipped from III to VI.
http://www.sandyblogs.com/techlink/2...dexron-vi.html
Friction Stability (improved 100%)
120% improvement in clutch durability
DEXRON-VI maintains an almost constant viscosity over time, while the viscosity of DEXRON-III degrades considerably.
Foaming Resistance (improved 150%)
Oxidation Resistance (improved 100%)
That seems like some damn good Transmission insurance if you ask me.
Blwn99x
03-24-2023 11:14 AM
turbo6c3
10-05-2015 06:11 PM
2002_Z28_Six_Speed
10-04-2015 01:34 PM
twake_410
09-21-2015 10:36 AM
fortune46x
09-16-2015 08:18 AM
Quick Reply: 60e type fluid?
