View Poll Results: Which should i go with?
Voters: 29. You may not vote on this poll
65e or 80e?????
#24
High on diesel fumes
I'd say 80E too. I did it, and yeah 1st gear isn't great, but I don't regret it. I like knowing that I can beat on the truck as much as I want and that the trans will take it all day long. I was so paranoid about my 60E after going through 4 in 3 months.
Plus, as stated above, the 80E has a 2.75/1.75 1st and 2nd gear available, that's what GM puts in the RV's. If gear ratios are a huge concern, you could do those gears.
#26
4L80E comes with 2.48 1.48 1.00 .75 ratios the early 4L80Es can use the 2.75 1.68 ratios that are available from TCI made for the TH400,but those ratios won't fit a late model 4L80E.
#28
Go with a Level 5 65e from FLT or just bite the bullit and go with a 80e. I wanted a 80e but Chuck told me I would be fine with his Level 5 so I went that way. I know before it is all over I will smoke the Level 5 and have a 80e sitting in there.
#30
Originally Posted by zippy
I would just stick with the 70E. There's no reason you can't find one to hold up to a Radix. Just have it built for your application.
