6l80 456 clutch pack
Well I burnt up the second set of 456 clutches. If the tune isn't the issue, what hard parts or seals would cause this failure? Rebuilt the trans with Sonax zip kit, up graded both Pistons, high rpm spring, all new bushings and seals. Even used a dial indicator to test the travel of the return springs. Flushed trans cooler and had converter cut/cleaned. The tuner had my truck pulling harder than it ever has and felt solid. Then a month later it started slipping then 2 day later they are toast?
2013 crew cab half ton. 5.3 turbo 3200 circle D trip disk. 450/480 hp/tq.
Anyone been here?
Anyone been here?
