6l80 456 clutch pack
Old 09-26-2016 | 11:17 PM
  #21
MattOKC's Avatar
Originally Posted by 07Softail
Did you do the Sonnax 4-5-6 apply piston kit? Yeah I have talked to Mike about these transmissions and he should be able to tune it but I have no experience or know anybody that has.
RT
Yes, I used both of Sonax's piston upgrades.
Old 09-26-2016 | 11:35 PM
  #22
MattOKC's Avatar
Originally Posted by Wolftrk99
Alot of the parts are the same... But the 6l90 cases are longer to accomodate the extra clutches in the 4-5-6 drum and 1-2-3-4/3-5-R drum as well as the taller rear planetaries.. Although i think i read somewhere in si that the number of clutches in them are application specific, not sure if it meant 45/50 vs 80 vs 90 or if it meant that a 6l80 in certain applications could have extra clutches...
I count 6 frictions 5 steels 1 wave plate. Are there other 6l80 aplications that have more frictions from GM? I also noticed that they are all coned, even with the Sonax apply piston. I don't know how much max pressure the tune has but a clutch pack that is coned doesn't seem like a lack of pressure would be the issue?
Old 09-26-2016 | 11:45 PM
  #23
Wolftrk99's Avatar
Coning is a combination of excessive heat and pressure.... How does the 4-5-6 hub itself look? Too much pressure can be as bad as not enough, may wanna check the seals on the piston and the sealing rings on the shaft....
Old 09-26-2016 | 11:56 PM
  #24
Wolftrk99's Avatar
Wait a minute..... As you stack it should be wave plate, steel, friction, steel, friction, steel friction etc, so you should havea wave plate, 6 steels and 6 frictions and then the backing plate
Old 09-27-2016 | 10:58 AM
  #25
MattOKC's Avatar
I'll count it again when I get back to the house
Old 09-27-2016 | 07:22 PM
  #26
MattOKC's Avatar
I counted wrong it's 6 frictions 6 steels 1 wave plate.
Old 09-27-2016 | 08:21 PM
  #27
Wolftrk99's Avatar
Ok... I was gonna say im surprised it even went into 4,5, or 6 if you left a steel out!!
Old 09-27-2016 | 09:53 PM
  #28
07Softail's Avatar
Is it required to install a new seal kit or can they be reused after pulling it apart?
RT
Old 09-27-2016 | 10:10 PM
  #29
Wolftrk99's Avatar
Thats kind of a loaded question, best answer ethically is to replace the seals eveytime, logic says since they are mostly o rings, if they havent been run very long use your judgement and do what you feel confortable with....that being said the valve body to case seals are a bit of a problem area, those i would replace.... But pump o ring and such if theyre not cut or flattened you should be fine...
Old 09-27-2016 | 10:33 PM
  #30
07Softail's Avatar
The valve body to pump and center section seals in particular is what I should have said....so those need replacing then right? Ahh hell I will buy a seal kit! Can you get me a part number for a 2014 6l80 seal kit please?
RT
