6L80E limits
Old 05-10-2011, 08:01 PM
  #31
Area47's Avatar
removing all of the torque management is a bad idea.
my sources on this information are far greater than someone poking away on a keyboard.
Old 05-10-2011, 08:13 PM
  #32
CDN SS's Avatar
I agree that is why I asking at what rate do you "reduce TM" it appears some are reducing it just not sure how and how much ....
in the older trucks the pcm allowed you reduce it eg typical was to remove 75% ...... It appears when using EFI Live on the T43 controller only option is On or Off ...soI am asking the expert sources ...do you "reduce " TM by adjustimg timing in the TM mode to "reduce" the amount of TM ...........or ??
Old 05-11-2011, 09:04 PM
  #33
Area47's Avatar
i have had mine set at .30 on shift torque factor since day one.
upshift torque reduction varies on my mood. since the driveshaft destruction. i turned it back on.
stall torque managment set at 8100 for enable, 8k for disable
tcc limit diable
600ft lbs.
max shift torque 6042
shift torque factor adder, stock.
shift times and shift pressures come into play with this as well.
spark reduction on mine is -5 degree's. only after i hammered the driveshaft. it was 0 for 20k miles. your choice on that
keep in mind, some of the torque management happens before, during, and after the shift. not all of it happens in one single motion.
Old 03-20-2014, 10:17 PM
  #34
malibu795's Avatar
so 3 years later, what are the updates of the 6L80 and 6L90?
looking at doing a LMM/6l90 repower
Old 03-21-2014, 08:20 AM
  #35
blownescalade62's Avatar
Same here looking to swap out my 6l80 for a 6L90 Awd
denalircsb
12-21-2020 09:04 AM
sTNT971
09-26-2015 06:27 AM
TAPyvehc93
09-12-2015 08:19 PM
FlowmasterMufflers
09-11-2015 03:32 PM
Alvin@PCMofNC
09-03-2015 06:38 AM
Quick Reply: 6L80E limits
