6lug Racestar wheels possibly coming out! (details inside)
#75
11 Second Truck Club
Curious what tires you guys are planning on running with the 17" fronts and rears?
Selection to match the F&R heights at 26" - 28" is pretty limited...at least with what I've been looking at.
M&H has a couple for the rear in both heights.
Fronts for a 17x7 seem to be pretty limited...in the tires I've run in the past, anyway.
#80
The wheels are drilled for conical seats so what ever lug you are using now should work on these.
As for tires, I have a friend that is a Bridgestone dealer so I will likely go with a set of Fuzions for the front. Sumitumo and Kumho are also good economical choices. The Dunlop Signatures are a similar touring tire so they will work fine if you have a hookup on them. Many of the same brands are available in a 215/60/17 which is just over 27" if a shorter tire is needed/wanted.
