6lug Racestar wheels possibly coming out! (details inside)
Old 02-22-2014, 10:45 AM
  #71
454navyss's Avatar
If the 17" fronts were 4-5" wide and the rears came in 16x10......
Old 02-22-2014, 12:19 PM
  #72
GMCtrk's Avatar
Why exactly do you want a 16" wheel? It still probably won't clear the brakes and the tire selection sucks. 15 or 17 is the way to go.
Old 02-22-2014, 12:40 PM
  #73
bigsapper's Avatar
So what are people running with the 17"?
Old 02-24-2014, 12:19 PM
  #74
454navyss's Avatar
My factory wheels are 16" and clear the brakes just fine
Old 02-24-2014, 01:25 PM
  #75
11 Second Truck Club
Superado's Avatar
Curious what tires you guys are planning on running with the 17" fronts and rears?
Selection to match the F&R heights at 26" - 28" is pretty limited...at least with what I've been looking at.
M&H has a couple for the rear in both heights.
Fronts for a 17x7 seem to be pretty limited...in the tires I've run in the past, anyway.
Old 02-24-2014, 03:07 PM
  #76
BigKID's Avatar
I plan to use a 215/65/17 on the front with 17x7. Just over 28" tall with a 6.5-7" tread and a lot higher load rating (>1700lbs) than 4.5" skinnies. If there were a 28x4.5 radial out with a good load rating, I might be pushing the 17x4 a little more.
Old 02-24-2014, 05:04 PM
  #77
Superado's Avatar
Like the Dunlop Signature?
Old 02-24-2014, 05:30 PM
  #78
hsiriyob's Avatar
I cant wait to start seeing these on our trucks
Old 02-24-2014, 05:46 PM
  #79
Superado's Avatar
Will the splined "tuner" lugs fit these wheels or will one need to get a more standard "mag wheel" lug with a specific length shank?
Old 02-24-2014, 10:58 PM
  #80
BigKID's Avatar
The wheels are drilled for conical seats so what ever lug you are using now should work on these.
As for tires, I have a friend that is a Bridgestone dealer so I will likely go with a set of Fuzions for the front. Sumitumo and Kumho are also good economical choices. The Dunlop Signatures are a similar touring tire so they will work fine if you have a hookup on them. Many of the same brands are available in a 215/60/17 which is just over 27" if a shorter tire is needed/wanted.
Quick Reply: 6lug Racestar wheels possibly coming out! (details inside)
