700r4 Skipping 2nd
700r4 Skipping 2nd
So I confirmed with 2 different shops today that my truck is in fact skipping second gear. It sounded like it to me, but I wanted more educated opinions.
Now comes the bad part. Both shops told me upwards of $1600 for a full rebuild if it so needs.
Any advice for things I can do myself first? For that price I'd rather go with a full engine and trans swap from the junkyard.
What is in your truck now? I have a 60E in my truck with LS1 , if built right then it can be a great transmission
As for your 700R4 , there is a patch job you can do that I really hate to say but you can.....Pull the servo cover off that houses the 2nd and 4th gear band. you can get to this without pulling the trans....pull the servos/pin out, and weld .200 onto the tip, this will engauge the band sooner and firmer..Its totally a redneck way to fix a trans but it will work if money is tight
Baltimore Whore
Didn't you say in your other thread you pull a trailer or trailers ? The 60 is the same as a 700r is. Your going to pay 2k or so for a good built 60e trans, I would suggest a built 60 at a minimum behind a 6.0. The 80 is just a stronger unit, even in stock for it is as strong as a built 60.
So you're saying I should go with an 80 instead of a 60 then?
drummer0415
11
10-24-2015 08:16 PM
