Are the 800# springs overkill in the Eaton LSD?
I'm in need of an Eaton to replace my G80. The standard springs are 400#, with 800# being an option. Does anyone know the extra cost and, more importantly, are the 800s worth that additional cost?
I have the 400# ones on my truck and they work just fine until one tire is compeletely off the ground then its like you have an open diff Im wishing I would have gotten the 800# springs. I have a 4wd also so I see situations like that more often then you so for you it may not be a big deal either one will get the job done but the 800# springs will act more like a locker than a posi.
From what I've heard they can chatter and slam. They're nice and strong for racing, but not necessarily for everyday use on the street. However, you can always ask BlownChevy, I believe he got the 800#ers for his Eaton.
Dropped my truck off today for the Eaton and 4.10 install. Installer told me he recommended taking the springs out alltogether for street use. I told him to leave them in and I'll see if I like it. He said the pre-load wasn't really required if you weren't going off road. This is coming from a guy who had been doing these for decades and his shop is dedicated to rearend/gear/posi installs and performance tranny builds. He doesn't have any springs in his eaton on his daily driver. If this is true then the 800#ers would probaly be overkill.
The place is called Maksymyks driveshafts. I don't have the number with me right now. He's in the FWB phone book. I had all the parts except for new axel seals ($16) and my total was 465.00 out the door.
Deep dig here... but anyone have any more input on going to the 800# springs?
I'm close to pulling the trigger on a new Eaton LSD Posi and wondering if I should just swap to the 800# springs before installing.
Also is it true that I'll also need the $120 #29492 24 steel plates to use the 800# springs?
This will all be going into a weekend warrior that never sees adverse weather and is driven very aggressively, drifting, donuts, rolling burnouts, quite a few test n tune track days, etc.... oh and is also 4WD, although I doubt either spring choice would effect 4hi launches much.
