80e 4x4 swap transfer case question
i read the sticky at the top about the input shaft swap on the t-case but if i bought a 4l80 with transfer case attached it would be drop in and i wouldn't have to re use my 4l60 transfer case, correct? from my research the 1500 and 2500's both use the np246 t-case. just wondering if theres any wiring difference or if im missing something.
Restricted User
the 2500 could have either the auto trac 246 or like a 261 or maybe 241 i dunno.... butt easy way to tell.. is if its a floor shift transfer case then it def not a 246..... but to answer ur specific question yes they are wired the same way.... there is no diff between the 1500 and 2500 246 t-case besides the diff input shafts..... 27 spline for the 4l60... 32 spline for the 4l80 but im sure you knew that
i have autotrac so its the 246 case. the reason i want to get a used 80e with transfer case is because i want to keep the stock 60e/transfer case untouched so if i want to back to stock it will be there ready. anyone done this?
Location: as far away from Koonerville as humanly possible
MileHighSierra
07-22-2015 11:19 PM
04BlackGmc
07-16-2015 04:10 PM
Gadgetized
07-07-2015 04:40 PM
