80e driveshaft??
Old 05-07-2011 | 10:27 PM
Jake99's Avatar
Im a bit confused, I picked up my 80e today and it looks to be no longer then the 60e, if it is its an inch at the most, do I still have to shorten it? I dont have a yoke yet cause I was told there are few different ones and im not shur what I need yet. once I get a yoke ill know I guess.
Old 05-07-2011 | 10:34 PM
TIM Z's Avatar
11 sec. Truck Mod
Is your trans installed?
Once it is, Take the yoke and slide it in the trans , shove it in till the rear seal is even with the line where the shiny/ corroded area is on the yoke. You want the seal to ride on the shiny part.
Then measure from Center of Yoke U JOINT to the face of the pinion where the straps bolt on( This is center of the rear UJOINT.) THat is the measure ment you need>
Should roughly be 2'' shorter shaft you will need from the stocker.
My Shaft (hehe) was 68'' C to C for the 60e, for the 80E i needed a 66'' C to C driveshaft.
Old 05-07-2011 | 11:22 PM
Jake99's Avatar
Ok, no the trans isnt installed yet. Ill try and find a yoke and get it bot and then ill install and see what I need. Thanks for the help ill plan on doing what you said, I to think thats the best way to do it so thats what im going to do.
Old 05-08-2011 | 09:56 AM
TIM Z's Avatar
11 sec. Truck Mod
No prob thats why were here! I need lots of help!
If you have any ??s PM me and i'll give ya my #.
Old 05-08-2011 | 05:02 PM
HorsePower Hunter's Avatar
I just did an 80 swap last week on my 2000 RC. I bought a ventless strange slip yoke and reused my stock driveshaft with no clearance issues. I slid the yoke all the way in the trans pulled an inch back marked it. Did my measuring and there was a 1/4in. difference. Threw a bastard joint in and it's done. The cross member was my only hang up.
Old 05-08-2011 | 05:13 PM
10 Second Truck Club
1350 yoke for 4l80 and driveshafts umlimited drivehsaft
Old 05-09-2011 | 06:51 PM
N20GMC's Avatar
I am also trying to figure out the best route to go. I have ordered everything for the swap on my 04 RCSB. And where I ordered the 4l80 from told me that it is 3/4 of an inch longer. And my truck has a stock steel driveshaft. So I was thinking just put the different yoke on it and be done. Whats everyone else's opinon on doing that?
Old 05-10-2011 | 07:09 PM
Jake99's Avatar
Thats what I want to try, buy the yoke and ujoint I need and see how close it is. I fear ill have to send in it to get the shaft shortend but if I do I do.
Old 05-12-2011 | 01:44 PM
N20GMC's Avatar
Well whatever you end up doing just post it in here. Thanks
Old 06-21-2011 | 08:18 PM
Jake99's Avatar
Ok to anyone who wanted to know what I ended up doing.. stock driveshaft then got a stock replacement u joint from Orileys and this slip yoke..
http://cgi.ebay.com/ebaymotors/ws/eB...ht_1526wt_1163
I slid the yoke all the way into the trans and had to pull it out right at an inch to bolt it to the axle. So I figered this should work fine. has maybe 300 miles on now everything seems to be working great.
Quick Reply: 80e driveshaft??
