80e swap front driveshaft
Old 12-04-2007 | 11:51 PM
blackbeautysilverado's Avatar
Default 80e swap front driveshaft
this could be a stupid question buy i don't hear about this as much as everything else, when a 4x4 does the 80e swap, do you have to modify the front driveshaft to be longer? or will the original fit well enough?
Old 12-04-2007 | 11:54 PM
SimpleManLance's Avatar
from my understanding both driveshafts have to be modified front made longer and the rear shorter.
Old 12-04-2007 | 11:55 PM
silveradol33's Avatar
Should all be the same, its bolts to the t-case and the diff, so that wont be a problem, I duno on newer stuff, but on the older trucks u have to change the t-case cause they have more splines on the output shaft. Everything else should be the same as far as length tho!
Old 12-04-2007 | 11:56 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
front has to be lengthened rear has to be shortened. The driveshaft shop just retubed my front driveshaft and re-used the yokes and ujoints. And cut my rear stocker down, then high speed balanced it. They are for sale too, I went back to a 60e after getting rid of my stroker motor.
Old 12-04-2007 | 11:58 PM
1slow01Z71's Avatar
What you are talking about is the output shaft on the 80e is larger so you have to take the tcase apart and swap the input gear to match the larger diameter output shaft of the 80e. Which I also have for sale.
Old 12-05-2007 | 01:33 AM
k well what's the easiest/cheapest way to modify the front shaft? i dont really want to have it cut and balanced. the rear one i bought the shorter yoke
Old 12-05-2007 | 09:16 AM
chevbowtie22's Avatar
For some reason the shorter rear yoke didn't work for me. My rear shaft was still about 2" too long. The front deffinetly needs to be lengthened. I think I needed to have my front lengthened about 2".
Old 12-05-2007 | 09:20 AM
dewmanshu's Avatar
Moderately Differentiated
(*****, selling **** :jest)
best way is to take to a driveline shop (big diesel repair shops usually have balancers on site) and have them do as cody has described. IMO, a high speed balance and proper build is the best way. If you don't lengthen it, it MAY work for you but it will be dangerously on the edge of the outputs. Not enough seating may cause bigger problems 100's or 1000's of miles later.
Don't forget to take your measurements with vehicle on ground, loaded.
Old 12-05-2007 | 03:04 PM
never messed with custom driveshafts, how much for that kind of work?
Old 12-05-2007 | 03:05 PM
1slow01Z71's Avatar
It cost me about 400 for the new front shaft and balance and the rear being cut down and balanced.
