89 gmc traction, how to?
Old 09-26-2016 | 08:44 AM
TwistedBigRig's Avatar
Default 89 gmc traction, how to?
So my truck doesn't get traction to save my life, I'm wanting to change that.
Future plans involve a 4 link set up but my budget isn't going to allow that for quite some time.
So I was thinking of removing the helper leaf, and installing a set of Caltracs, I'm sure someone has already done this what were your results?
Also what shocks should I be looking at for a dual duty daily/track truck?
Old 09-26-2016 | 01:45 PM
turboal1's Avatar
Default traction
I put on the Cal-Trac's, what a diff, truck used to hop up
and down like a Rabbit. also added a set of Nitto 555 extremes.
255x45x18, they really helped to. also check your pinion angle
to see if it's right. should be 2 to 4 deg down. how old are your
springs and shocks ? they make a big diff.
Old 09-27-2016 | 03:13 PM
I'm assuming the springs and shocks are original equipment, I heard morose trick Springs and loosening the a arms with removing the helper spring and new shocks is the way to go, I just don't want it to loose drivability at highway speeds to get it to hook from a stop
Old 10-01-2016 | 08:21 PM
turboal1's Avatar
Default springs
race springs are not good for street use. they bottom out to easy.
you didn't say what model truck your working on ?
MikeD.
10-05-2016 01:46 PM
JonToski187
09-13-2016 05:11 PM
Silverado256
09-04-2016 11:49 PM
GM1697
09-01-2016 10:03 PM
RNSAK
08-30-2016 01:16 PM
