what 14 bots have abs sensors at both wheels? i just remembered mine has them on both wheels not just one single. i'm not sure how the leaf 14bolts are
As far as I know the trucks didn't have wheel speed sensors in the rear. The TBSS supposedly did but it is narrower.
well, damn! sounds like i need to just run the 9.5 from the newer suv's i was looking foward to just building my own and getting off a little cheaper.
Every one always thinks its cheaper to build from scratch but when you start opening them up and changing gears, lockers, bearings, seals and so on it all starts adding up... You could easily spend the same amount modifying one to fit...
either way i would want a tru trac and stronger axles. this will be for a diesel build. i figure if tbss guys can pull of 1.3 60's then it should be ok for a duramax daily driver.
