9.5" 14-Bolt 5-Link Rear Swap
#61
I think you're on the right path to getting the results you wanted. I will say that bolting in a rear end is by far better than fabbing one up. Shouldn't have to worry that something is off. The 9.5" gov-lock is even a ton stronger than the 8.6" is. Just make sure that when you heat the tires that both lock in. If they don't let up real quick.
Honestly, when I started all this 4 years ago my "plan" was to just give my little 4.8 some umph...never thought that I would be chasing 600/600! Now I'm just hoping that the Gov-Loc will make it through 2009 because I fear that my FLT Level 4 4L60 will be the next casualty (likely an input or output shaft failure), and when it does I'll be moving up to a built 4L85...need to put cash in the bank for that one!
#66
In and done, Had to narrow the axle 3/4" from ea. end. Also converted the outer bearing journals to the older large dia. version to accept larger A/M axles.
OEM 3.73 gears and a Tru-Trac.
Smoked the tires and broke the tranny........
next mod????? 4L80!
Whats worse HP or Weight? Or wanting both?
next mod????? 4L80!
#67
Custm2500's Rude Friend
next mod????? 4L80!
next mod????? 4L80!
More Details on your 9.5 set up??? Pictures??? Specific info On the older Larger dia Bearing you converted to??? What had to be done to make them work for your application???
There is so little info posted about specific 9.5 14 bolt details.
Any specific Info would be much appericated!
#68
next mod????? 4L80!
next mod????? 4L80!
#69
@.100 on the inner and .200 on the outer.
10 bolt axles are Not even 1.50 Dia.(Never carred to measure them) SUV axle shaft Lenght is 33 1/2 ea.
OBS 14 bolt axles are 1.705 Yukon A/M axle lenght 33 1/4 ea.
NBS-NNBS F/S SUV 14 bolt are 1.618 and 34" in lenght.
MY Axle was from a 2008 Escalade, I removed the axles,cut the tubes down 3/4" on ea. side. Swapped out the ends from an OBS 14 bolt axle,I then corrected them for proper offset from drum to disc,clocked the flanges accordingly and welded them. I removed the wheel speed sensors,and installed the above mentioned yukon axles listed along with a detroit tru-trac. Everything bolted up properly with the wheels sitting back in the proper location.(within 1/4" combined)
#70
