9.5" 14 bolt fitment?
I think I found a 9.5" 14 bolt. I have a 2000 ECSB, the rear I found is said to be out of a newer 1500 (2006 I think?) crew cab it's a hybird axle (AXN).. I'm just making sure it'll bolt in, and my disc brakes will swap over somewhat easy?? Thanks, Matt
Well the salvage yard called me back up, and when they had it checked out, a spring perch was jacked, and a axle tube was also bent up, so that's a no go.. Do the NNBS 9.5" AXN 14 bolts directly swap in too?, asumming I use the right u-joint of cousre.. Thanks guys
iregret
09-07-2015 01:20 PM
