9.5", 14-bolt, SF Full-Size Rear with Discs?
Rear brakes arent nearly as important, Im going with their alumasports for the front, Brembo wants crazy money with their stuff and wilwood is pretty much in the same boat. Baers 6 pistons arent available for the rear so what are you going with?
Originally Posted by 00Z71
The 2500 with 6.0 have ff 9.5", 8.1's get 10.5", and d-max's get 11.5"
jessie1 (10-20-2022)
i havent tried thsi yet but im thinking the brackets off a TBSS 14bolt will line up with the silverado 14bolt. i havent tried it but im thinking this will work. also some 3/4 ton trucks have the SF 14bolt
Originally Posted by TBSS
I thought 10.5" means FF while 9.5" means SF...do I understand this correctly?
Originally Posted by Mort
That is correct to the best of my knowledge. The 2500 and 1500HD have the 9.5" 14 bolt semi floating rear and the 2500HD and 3500 have the 10.5" 14 bolt full floating rear. The problem is all of these axles are 8 lug applications. My '03 has discs on the rear. I am not sure what the newer ones have or when they added discs to the rear.
all have 14 bolt rear covers
the 9.5" had is SF found in 1500HD/2500 with 6L/4L80E
the 10.5" is FF, found on 2500HD's with the 6L/4L80E
the 11.5" is FF, found in 2500HD's/3500 with 8.1L/Duramax/Allison
the older and newer 6 lug applications complicate the mix a little bit
A 10.5" 14-bolt can be converted to non-floating with custom ends and custom shafts. I originally had mine built for 5-lug wheels, more recently I changed all 4 corners to 6-lug. Discs are available for the conversion - they are the same ones that fit 12-bolt rears that originally had JB6 11" drums. I went with drums.
You dont trust Baer to slow you down?
