9.5", 14-bolt, SF Full-Size Rear with Discs?
Old 12-10-2006 | 11:53 PM
  #31
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Originally Posted by James B.
A 10.5" 14-bolt can be converted to non-floating with custom ends and custom shafts. I originally had mine built for 5-lug wheels, more recently I changed all 4 corners to 6-lug. Discs are available for the conversion - they are the same ones that fit 12-bolt rears that originally had JB6 11" drums. I went with drums.
Do you happen to know is the discs would fit the JH6 disc option for the 9.5's? Or a source for the discs for that matter
Old 12-11-2006 | 12:40 AM
  #32
James B.'s Avatar
I don't know who's kit fits on these. It's just a matter of matching the 4-bolt backing plate flange and the lug pattern. I don't see why a set of stock discs and calipers from a 1500 couldn't be made to fit with a little modification.
Fitz57 (09-08-2018)
Old 12-11-2006 | 06:50 AM
  #33
Quik's Avatar
5 year bitches!
The Bear folks are idiots... They will try to tell you that every axle from a non-HD truck takes the same Bear kit... despite the fact that the caliper anchors come in 2 distinct varieties (1 is ~4.5" and one is ~7.75" center bolt hole to center bolt hole). They also told me that they don't have dimensions for their kits available and don't know which variety it fits, because, you guessed it, there is only one size from GM... When I pointed out that I was measuring two calipers from 03, one from a SSS and one from a 1500 crew cab, he hung up. Wilwood is a bit better, but still has no solution if you want 6 lug.
I'd love to hear more about this relocation bracket that lets you use rotors from a 6 lug truck. Lemme tell you -- it ain't gonna happen. The hat is .45" too deep, so the rotor itself is the problem, not the caliper placement.
BTW, I had no trouble getting after market parts for the my 9.5. Brakes, yes, but gears, carriers, axles, even a TA girdle were readily available. Counting a brand new GM housing (which was $1100) I build a detroit locker with custom axles and micronited R&P for < $3k. Pretty comparable to the 12 bolt or ford 9" sets I saw.
link for TA girdle
Old 12-11-2006 | 07:53 AM
  #34
I AM A MOTHERF*CKER
The hat is too deep. Tightening the lugs pins the rotor to the caliper bracket, and even with no calipers installed, will rip off the dust shield and may cause problems spinning the axle (once I saw how bad it was, I didn't try to spin them). .45" is too much for a spacer according to Revolution (used to be precision brakes).
Old 12-11-2006 | 07:55 AM
  #35
I AM A MOTHERF*CKER
Originally Posted by Quik
link for TA girdle
http://www.taperformance.com/rearend.htm
TA 1803 - in the middle
Old 04-28-2020 | 05:17 AM
  #36
Coco Alberto's Avatar
Registered User
Hello James ! I read about your axle setup good build man ,I need same setup ? where did you do this setup any recommendation please help ?
Troy5061
08-11-2017 10:53 AM
oakley6575
02-21-2012 09:40 PM
Turbo 6.0
09-27-2008 01:49 PM
Quik
09-09-2006 09:32 PM
