'95 nv3500 on a 2002 LQ4, slave and clutch need help
Old 02-08-2016 | 07:58 PM
Alco's Avatar
Default '95 nv3500 on a 2002 LQ4, slave and clutch need help
I might be over thinking this ( probably ) but I want to run a slave of a 2002 silverado instead of the fork that came with the 1995 transmission .
I have clearence issue and want to cut the case to remove the portion where the clutch fork and slave sit's
Can I just delete the clutch fork and slave and buy a clutch flywheel from a 02 silverado bolt it to the Lq4 and buy a 2002 slave and install it in the case without any major mods ?
2002 slave
1995 slave
Old 02-12-2016 | 09:55 PM
Alco's Avatar
no body ?
Old 02-12-2016 | 10:00 PM
CCrowell2's Avatar
Yes I think so, my slave in my 97 looked like the 2002 slave.
Old 02-14-2016 | 07:23 AM
Alco's Avatar
ok from what I found the input shaft bearing retainer as to be replace with a newer model if it's only that well it's gonna be an easy conversion !
Old 06-27-2016 | 09:07 PM
_zebra's Avatar
makes children cry
i know it's 4 months later, but...
check your master cylinder line connection first. my 99 has a roll pin connection up top & the quick-connect on the slave. i believe 01 or 02 was when they switched it to the quick-connect up top with the line roll pinned into the slave
Tbss6
01-31-2016 09:11 AM
carbed94z
01-21-2016 06:18 PM
Aboss
01-17-2016 12:15 PM
rms-man
01-12-2016 06:18 PM
