99-06 gm truck 4wd front differential compatibility?
Old 05-25-2020 | 01:21 PM
10 Second Club
Default 99-06 gm truck 4wd front differential compatibility?
I have an 05 GMC Sierra SLE, factory 3.42s. I want to go up to 4.10s, a local guy has a front diff out of a 99 Z71 NBS that he parted out. Will it work? Are there any differences between years? I have been told that the transfer cases changed around 03-04, true? I feel like I would rather swap out the front diff vs. pulling mine and taking it somewhere to get the ring and pinion changed.
Old 05-25-2020 | 02:09 PM
wretched73's Avatar
It will fit but the one from a 99 probably has a floor shifter and yours is electronic shift, better off finding an exact replacement
Old 05-25-2020 | 05:23 PM
arthursc2's Avatar
Should be a plug and play swap. Whether floor shift or not, all the front diffs are electric, unless AWD
so to clarify; 4wd diffs are all compatible, AWD diffs are the odd duck
Bluecollar Hotrods (05-25-2020)
Red99TA
12-31-2010 08:12 PM
AKZ71
04-10-2008 11:15 AM
Greg Fell
10-24-2007 08:14 PM
