Ability to retain factory gear indicator with ratchet shifter?
Old 10-22-2020 | 01:34 PM
Sloop's Avatar
Default Ability to retain factory gear indicator with ratchet shifter?
Has anyone installed a ratchet shifter setup and was able to retain the factory gear indication in the gauge cluster? Wondering if and how it can be done.
Old 10-22-2020 | 02:02 PM
MaroonMonsterLS1's Avatar
If you're able to keep the neutral safety switch with your ratchet shifter then you should be able to keep the dash display
RedXray (10-23-2020)
Old 10-23-2020 | 11:12 PM
RedXray's Avatar
100% Redneck
Yeah I did the B&M truck megashifter and the factory PRNDL switch on the side of the transmission keeps the gear selector indicators just like factory. If it's an older truck (you didn't post year) with a non electronic transmission they give you a mechanical indicator option and micro switches for the neutral safety in the shifter box.
Old 10-24-2020 | 04:01 PM
terravast4's Avatar
Is all the wiring for the megashifter done through the PRNDL switch?
Old 10-26-2020 | 04:09 PM
Sloop's Avatar
Yes sorry, its an 03. Converting from a manual to auto but i have a bcm and everything needed for the automatic side to work and ill have the manual column.
Sounds like im good to go!
Old 10-26-2020 | 05:22 PM
RedXray's Avatar
100% Redneck
Correct nothing on the shifter, except of course the shift cable.
Old 10-28-2020 | 09:06 AM
Sloop's Avatar
Nice setup! Did you make that bracket for the shifter to sit on?
Old 10-28-2020 | 03:41 PM
RedXray's Avatar
100% Redneck
It comes with the "Truck/SUV" Megashifter (part number 80680). It lifts the shifter and also gives it the perfect angle so the shift handle will clear the jump seat on the GMT-800 trucks. If you choose to do the 03+ console (gut out) mod it needs only a few spacers to clear the console's lid.
B&M 80680 B&M 80680
hafftrak (09-15-2024)
Old 01-02-2021 | 10:55 PM
0235SS93's Avatar
B&M 80680
do you have a better picture of the boot and cup holder? I just put this shifter in and cant find a happy spot for the boot
Old 02-20-2021 | 08:49 PM
sschevellefan's Avatar
B&M 80680
Id be curious what you had to do to the cup holder. I have the same console in my 2000 Sierra and I would love to have a floor shift in it.
