ABS Light When i Launch From A DIG ???
Banned
i recentley installed a circle D 3,200 single disc ... well i diddnt install it myself but anyways ... ever since the stall was put in ,, i launch from a dig and the abs light comes on ... if i hit the brakes hard the tires lock up nasty ... i turn the truck off and leave it sit for a few mins and it goes away but EVERYTIME i launch the abs light turns on .. wtf is going on here ???
Do you brake stall it and launch? Or just flash the converter? A lot of times when the abs lights kick on it can be a hub assembly.. Jack it up and see if there any slack or noise or anything coming from either side. If not I would just check the sensors and wiring and after that I don't know what to tell ya
11 Second Truck Club
Don't your style of truck have 4 wheel ABS with tone rings on each corner? I'd be willing to bet your getting the tires spinning at different speeds and your abs light is coming on to indicate that there is an erratic speed change...
My ABS light comes on sometimes in the water box, but it always goes back off after I restart the truck and drive it a few feet.
carid
10-28-2015 08:24 AM
drummer0415
11
10-24-2015 08:16 PM
TAPyvehc93
09-12-2015 08:19 PM
