abs and parking brake light came on after gear swap
Old 10-10-2009, 01:08 AM
dirt track racer 81's Avatar
Originally Posted by Spoolin
He's now in REP mode...
may that truck Rest En Peace
Old 10-10-2009, 01:12 AM
SLOXCAB's Avatar
Ya spoolin said it I'm in rep mode abs and parking brake lights are on and can't go more that 10 mph--any info would help-and turned it off and then on to get it home but the check engine light is still on-im in the so cal area if anyone can help
Old 10-10-2009, 01:19 AM
you should be able to disconnect your battery and get it out of rep mode..in some instances.. but im leaning towards somethin in the tune is not set right
Old 10-10-2009, 01:24 AM
GFYS and STFU
Spoolin's Avatar
Lee you should of done this when you got back from SF or before you went to Justin's!! I'll be back on Monday, we can use my HPT since your already licensed to try and fix it but you need to figure out what's wrong with it. Ask Joseph, if not look up "Hooper's rear ends" in sunvalley and ask them if they would know what's wrong with it. If they say it's the install I would suggest towing it to them. They've done a few of my rear-ends and they do great work.
Old 10-10-2009, 01:43 AM
SLOXCAB's Avatar
Ya I know I'm a dumbass--going to meet up with joseph tomorrow and see what his scanner says
Old 10-10-2009, 01:57 AM
SLOXCAB's Avatar
My truck just earned its name F.U.B.A.R.
Old 10-10-2009, 04:27 AM
Where's the Beef?
viciousknid's Avatar
I highly doubt it had to do with the install. other than the gears themselves being a different size.
All fixes i've seen have been the BCM needing reflashed to correct a factory error with the ABS. Fixing a loose connection to the ABS fuse on the fuse box under the hood. And adjusting the tire/gear size in the tune and then fine tuning the speedo because the pcm had a hard time with the sizes or something.
Old 10-10-2009, 12:35 PM
SLOXCAB's Avatar
How much does the dealer charge to change up the BCM
Old 10-10-2009, 01:55 PM
GMCtrk's Avatar
This is odd. I had the SES light too after the gear swap, but I drove it for a couple weeks like that. But I dont think the 99-02 have REP mode. Is there any way you can post up your tune?
Old 10-10-2009, 02:26 PM
SLOXCAB's Avatar
My tune is a blackbear street tune-it should be figured out soon-
Quick Reply: abs and parking brake light came on after gear swap
