abs and parking brake light came on after gear swap
Ya spoolin said it I'm in rep mode abs and parking brake lights are on and can't go more that 10 mph--any info would help-and turned it off and then on to get it home but the check engine light is still on-im in the so cal area if anyone can help
GFYS and STFU
Lee you should of done this when you got back from SF or before you went to Justin's!! I'll be back on Monday, we can use my HPT since your already licensed to try and fix it but you need to figure out what's wrong with it. Ask Joseph, if not look up "Hooper's rear ends" in sunvalley and ask them if they would know what's wrong with it. If they say it's the install I would suggest towing it to them. They've done a few of my rear-ends and they do great work.
Where's the Beef?
I highly doubt it had to do with the install. other than the gears themselves being a different size.
All fixes i've seen have been the BCM needing reflashed to correct a factory error with the ABS. Fixing a loose connection to the ABS fuse on the fuse box under the hood. And adjusting the tire/gear size in the tune and then fine tuning the speedo because the pcm had a hard time with the sizes or something.
