Accum piston spring
FormerVendor
With the HD-2 kit you will not need any accumulator springs. We get calls all the time about harsh 1-2 shifts when guy's buy kits from our competitors. Keep in mind that you will not get any technical assistance when you purchase a kit from them. It might be cheaper than ours but when you have a problem your pretty much on your own or you will need to call trans-go. Good luck. Vince
formerly 1BADC10 (12/14/2011)
Um... if my memory is correct, doesn't the HD2 come with the recommended hardware from Transgo? I'll have to go and look at the instructions, but I didn't buy anything outside of what came with that. One thing you'll want to remember is DO NOT INSTALL MORE THAN ONE WASHER! ...at least not for a DD. Shifts are way too firm for DD use.
sorry about digging up an old thread but I just installed a the hd-2 kit in a my new tranny which I have not put in the truck yet. I set it up according to the instructions but i did not use ANY washers, how would you think this will shift? It went together quite different from how I pulled it apart, the piston is flipped over and there is now springs in each side of it - according to the transgo instructions. Should I put one washer in? Truck is a daily driver and i dont want it to shift overly aggressive. I also have a 2500 stall which will be going in with this tranny.
jtphelps289
09-29-2015 12:00 PM
