Accumulator piston
Accumulator piston
I'm going to be changing the transmission filter soon and I was going to install the aluminum 1-2 piston. Is there also another plastic piston above the 1-2 deeper in the case? I've already searched and haven't really came up with much.
FormerVendor
Sorry. Yes the one in the valve body is the forward accumulator. The one that is held in by three bolts that bolts to the case is the 1-2. The one in the case is the 3-4 but is already aluminum and is probably ok. The 2-3 accumulator is apart of the 2nd gear servo. This is one you do not need to address unless you are installing a vet servo. At that point all you have to do is transfer the guts out of your old servo. Now you know where all of them are located.
