Accumulator Piston fitment?
Old 10-22-2008 | 10:19 AM
StrokerAce03's Avatar
Default Accumulator Piston fitment?
I'm in the process of doing a shift kit install with all the goodies. I got the pinless accumulator pistons for the forward and 1-2 accumulator pistons and they fit really tight. Are they supposed to be that close or should they slide right in?
This is the first time I've done anything to a transmission so I want to get everything right the first time.
Old 10-22-2008 | 10:31 AM
BlackGMC's Avatar
Resident Retard
Did you put vasoline on the rubber oring before you put it in? I dont remember how mine was, but I remember hating every second installing that shift kit and goodies.... Next time I will just pay a professional... Not to mention getting soaked in tranny fluid... But it was worth it in the end...
Old 10-22-2008 | 12:32 PM
Yeah I lubed the orings before I put them on the pistons. I also lubed the bores with ATF and they just seem a lot tighter than factory.
I didn't get soaked with fluid since its sitting the floor in my garage
Old 10-22-2008 | 03:08 PM
built408's Avatar
coat them with atf, the pinless pistons have two oring seals, and they must fit very tight to keep them from getting cocked in the bore.
Old 10-22-2008 | 03:38 PM
Dezert1500's Avatar
x2, what part numbers do you have? My fwd and 1-2 accumulator pistons fit fine with alittle bit of ATF on the new orings.
Old 10-22-2008 | 04:44 PM
I don't remember the part numbers but they're made by Sonnax. I pulled them and coated them again and they fit fine; its just that the stock pistons came out a lot easier.
Wolftrk99
12-03-2015 08:12 PM
lukn4trbl355
10-21-2015 11:19 PM
turbo6c3
10-05-2015 06:11 PM
sTNT971
09-26-2015 04:22 PM
Quick Reply: Accumulator Piston fitment?
