Aftermarket Diff Cover won't fit !!!
My T/A cover wouldn't fit, I found this out when I had my Eaton and 4.10's installed. My stock panhard bar was too close to the diff and because the T/A cover was so thick, there was not enough room for it. Stuff you leaf spring guys don't have to worry about, fortunately.
So I'm either thinking a different diff cover, modifying the stock panhard, or an aftermarket panhard bar. Any ideas?
I had the stock G80 +3.73's, and upgraded to an Eaton LSD + 4.10's.
I just wanted to beef up the rear as much as I could. Good diff covers can prevent the diff housings from twisting...plus that T/A cover had screws that bolted up against the Eaton carrier, making it even stronger.
I may still be able to use it. I'm working with someone who said we might be able to modify the stock panhard bar, or get an aftermarket one. If that doesn't work out, I'll let you know.
Originally Posted by redaddiction
Where can we get the cover for us leaf spring guys ?
