Ahh... yet another 4L60E rebuild
#21
formerly 1BADC10 (12/14/2011)
Originally Posted by Tootall
from what I've read. . . (I'm no builder) If you let the clutches soak, they chance the over all thickness/tolerance. I've read that it's better to set the clearances, then take the clutches back out and let them soak.
#22
Originally Posted by 1BADC10
Wouldn't you end up with a tighter clearance? Is that considered the preferred method amongst trans builders? I was told to soak before, and you'll see closer to your actual "recommended" clearance level in normal operation. Maybe that's incorrect.
yes . . . that was idea behind it. It was another thread just like yours. It was another 4L60e rebuild (basement rebuild was the title). There were a couple of builders that chimed in about it.
here's the thread that I was talking about
https://ls1tech.com/forums/showthread.php?t=631230
#29
I just noticed how his case is cracked at the bell, to the right of where his ratchet strap is at.
#30
FormerVendor
The gentleman in the picture coded that picture "daretorebuild". Left click on it in his thread and try to save it in your computer. That is what the picture name comes up as. Thought it was pretty funny! I guess I have a sick sense of humor. I have talked to him a couple of times through his build and seems like a good guy. He really did put a lot of work into the thread. But this just shows that this **** is not as easy as it looks. I personally would build, document, install, drive for more than once around the block, and then start working on the thread, so not to look like an idiot. There were quite a few members that blasted this poor guy during the thread. I give him credit for trying.
