Alignment off?
Thats allright. I did my last alignment with 2 strings, 4 lawn chairs and a tapemeasure. after I went to the "good" alignment shop and $80 later they gave me the print out and my solid rear axle has toe and camber LOFL. abvoiusly their stuff (Or sears) wont fit 20" rims and the new rim protector tires.
It helps people know if their axle halves are warped or bent.
When my 2000 Chevy Silverado was rear-ended bad, I went to the alignment shop (NTB), to have the alignment looked at after it was repaired. The truck went to the right really bad after it was fixed. One side of the axle (right) had a bad neg toe of .58, the left side read a normal .09. There will always be a little toe in or out. No axle is perfect. Though the -.58 on one side was unexceptable.
I then took it back to the repair shop, they had to re-pull the frame on the frame machine. After they did, I took it back to the alignment shop, I had .08 and .12 toe readings at the rear axle. The truck drove straight after that.
So, getting a reading of your axles toe and camber readings is good to have and know.
Jim
I'll look for that print out and tell you the specs if I can find it. The part I was laughing at was their adapter wouldn't fit in far enough to seat up to the rim, I knew it couldn't be very accurate cause all four points of the adapter went in a different amount. I'm going to put my stock wheels back on and have it checked. It was NTB that I went to, I went to sears first and their adapter had the same problem so they wouldn't even try. Thanks for the positive info though
Back from getting realigned. All is good.
Alignment was square as far as thrust angle but he did fine adjust the front a bit and I'm steering straight.
Dropped the driveshaft and measured pinion angles, needed to replace 4* shims with 2-2.5* for parallel angle, went with 3*. I cant feel any more vibration, must be close enough.
Which is better for FI pick-ups a one-piece aluminum DS or a steel DS?
PT's Slowest Truck
Originally Posted by CHEVY6000VHO
Explain pulling to the right a hair?
A hair is a drift. Very common with the GM trucks. More than likely, if it's a slight pull or drift like you describe, an alignment correction to the Caster adjustment will fix you right up. A -1.0 to -1.4 Caster split works best on the GM trucks. They tend to like to track to the right from the factory.
I have a -1.2 caster split and I still have a slight drift to the right. I will have them bump it to a -1.5 next time.
Just let me know what your alignment specs are when you get the alignment done. A good alignment shop will give you the print out of the alignment specs.
Hope you get it all straightened out.
Jim
Jim
Since I lowered my truck via torsion keys, it was a little tricky to get the camber where I wanted it, but once I did (-.5* on both sides) I now have cross caster that is almost 0 (I think that I'm at about +4.0 on each side if I remember correctly). The drift no longer seems to favor the right side as strongly though, now it's just sensitive to the road in general...on a flat road (which is hard to find), it will track pretty straight, maybe just slightly to the right (if I hold the wheel straight, it goes straight )...if the road is crowned left, it drifts left, if right, it goes right. FWIW, lowering this truck not only enhanced it's appearance and attitude, but also cured a driveline vibration I used to have at 60-75ish mph, and helped it to track straight with 0* of cross caster...
I guess this truck has been destined to be a sport truck instead of an off roader from the start...pretty sure that I heard a "sigh" from under the hood the day I peeled the Z71 decals off
(sorry about trailing off and hijacking on ya trever...glad you got it "straightened out"...pun intended)
lukn4trbl355
10-21-2015 11:19 PM
