Are all 4l60 the same?
I have a 01 silverado and I took the old 4l60 out and went with a turbo 400 behind my turbo setup but now I am going back to a stock setup I got my 4.8 but I need to find a stock 4l60. Are the plugs all the same on those trannys? Please Help
Just make sure that the pins on the main harness connector are the same as what you have. As early as 06 you could have a turbine speed sensor in these units and these will have more pins. I have swapped early and later 60E units with the two styles of EPC solenoids and have not run into an issue doing this. HTH Vince
Silver8ado
04-18-2017 08:39 PM
